low compression on 98 175 johnson faststrike
98 stratos
have low compression in 1 cyliner(60) and others are around 95. wondering what could of done this and why would it happen.
the reason i checked it was because it would run fine ok some times and other times it would idle down and run rough. but then i would squeze the fuel pump ball a little it would idle back up for a minute. is this the copression doing this or is it a fuel delivery problem?
again the motor is fuel injected 98 johnson 175 faststrike
please let me know what u think
any thing would be helpfull
thanks.
jonesg
Re: low compression on 98 175 johnson faststrike
You sure its fuel injected, not oil injected?
sounds like a dirty carb, but could be clogged fuel injector if thats what it has.
You could just have a blown head gasket, only to find out is pull the head and look.
James R
If you have one cylinder with bad compression then that's the first thing to correct. Until that's done forget anything else.
Capt Ron
EXACTLY!!!
Capt Ron
