low compression????
dhonda
hey, i have a 1960 gale 40hp that i took out the other day and when i did so i noticed that after driving it for 10-15 mins at a crusing speed the motor starts surging so when i took the motor home i bought some new fuel lines and cleaned the fuel pump filter. I also checked the compression and noticed that the top cylinder has 80psi and the bottom has 70psi, keep in mind that i used a cheap harborfreight compression checker. My question is how low does the compression have to be to effect the performance of the engine?
Thanks, Derek
dirtdog38
Re: low compression????
i like to see over 100. but they will run with less than u have. the suge id say is a diffrent thing going on bad gas or points , carb look ther run a little more oil in the gas on that old motor they like it. as long as you dont foul plugs is the main thing ther
watergecko
80/70 is ok, what ur looking for is within 10% on the cylinders, ur at 12.5% but i think u might b able to improve those numbers by doing a decarb. Check out the top secret file at top of thread for how to. Do a decarb, and redo the comp test, u may just have a sticky ring.
