Re: Low cylinder presure
OK, the head checked out, they replaced the intake and exhaust valves, as well as seats for the cylinder that had low pressure. At this point I want to put it back together and re-check my cylinder pressure. My repair manual has got me a little confused. <br /> Are the torque specs the same for the 4cyl and 6cyl. My manual only shows one set of torqe specs for both 4 and 6cyl. Head bolts are 93ft lb, maifold to head at 23, and and does not specify torqe on the the water seperation tube.
