wildk
Thread starter- Joined
- Mar 5, 2020
- 18
Hi all, first post here. Honestly I should have joined this forum a while ago. I have a '97 Eastern 27' Downeast boat with a mercruiser 383 stroker (scorpion?) that burns alot of oil. Sorry for the marathon post, but here goes:
Here's the backstory:
I bought this boat last April primarily for tuna fishing and it had a 1997 Mercruiser 350 with a bravo 2 with ~4000 hours on it. About 10 hours into my use of it, the motor failed. It seemed one of the exhaust manifolds was cracked and I hadn't noticed, and the engine ingested water and hydro-locked. Bummer, but when I bought it i figured it would be up for a repower sooner rather than later due to the high hours.
So I found a 2006 Mercruiser 383 motor with less than 100 hours on it for a somewhat OK deal. The motor had perfect compression, and was generally really clean, so I picked it up, changed the thermostat, water pump etc, and got to installing it in the boat. It ran great, and produced significantly more power than the old motor, and the MPI fuel injection system was a welcome improvement over the carburated motor.
Now:
I soon realized my low-hour 383 burns alot of oil. No warranty from the shop i got the motor from so I am stuck with this problem now. It seems to burn about 1 quart every 5-7 hours. We put the boat away in the fall, and said we would deal with it in the spring and, well... here we are. Aside from burning oil the engine runs great. The compression on each cylinder is still exactly what it was when I bought the motor -185psi, and not a huge difference between hot and cold compression - seems about perfect. When each spark plug comes out, though, it is absolutely drenched in oil.
The prevailing wisdom last fall was that the valve seals had degraded from sitting. I don't know how long this engine sat to be honest. It's possible it sat for the better part of 12 years, but it is just not known. The guy I fish with has a friend who builds chevy motors for old muscle cars, and this guy is now telling me that I've got stuck rings, and that it needs a full rebuild (that of course he would be happy to charge me for), because there's no way valve seals could lead to this level of oil consumption. I am not sure how i could have stuck rings on all 8 pistons to be honest, with perfect compression and no other adverse effects.
My theory is there is alot more potential for oil consumption on a boat engine like this because that engine is working way harder than it would in any car. It's pushing a fairly large, heavy, and inefficient boat, and running at higher throttles quite a bit of the time. My fishing buddy is pressuring me to just drop the money and have this guy rebuild it (of course he wants to go catch some fish, so do i), but i am hesitant to go that route because the service would likely cost what the motor cost to begin with.
Any thoughts, past experience with oil consumption? Any advice is much appreciated. Thank you
Now:
