ADK_Boater
Thread starter- Joined
- Jun 29, 2010
- 217
Hey everybody,
I have a '72 Johnson 85hp and need to clean the low idle jets.
I bought 30 gauge steel wire and I plan on filing the ends round to not scratch the he walls of the jets.
I also bought 20 gauge aluminum wire too in case 30 gauge is insufficient.
After I remove the frost caps what technique should I use?
Gentle flossing?
Or just run the wire through in on direction.
Also, should I lube with carb cleaner (I realize that is not much of a lube) or maybe a little fogging oil?
What way is the right way...I'll do anything to avoid damage.
Thanks again!
Gentle flossing?
Thanks again!
