low mph suzuki dt115
rgg
Own a 18ft cc (1200 lb hull wt)with a dt115 suz (370 lbs).<br />I am having problems with top end speed and rpm. Specs say should be 5200 to 5750 rpm. The prop is a 17 in. alum 3 blade just recond. It's a long story and alot of work and testing done to this engine but top end speed is 37 mph (gps) and rpm is 5400 to 5600 no matter what weight load is put in the boat. The work done so far is : all filters changed, carbs rebuilt,new fuel pump, new bulb, new plugs new fuel connects, timing checked and okay, new tach. Math says this boat with this engine should do 48 to 50 mph. Am I missing something?
boaterntexas
Re: low mph suzuki dt115
Sounds just like my 17.5" fiberglass bass boat with a 115 merc.. my boat is onl, 1976 and I have a ss 21 pitch prop, which needs work, MY boat will easly hit 40 mph, but once you start addign whieght and people it really starts workign hard.
JB
Howdy, RGG.<br /><br />You might be missing on the boat weight on the water, loaded. I estimate 2000lb. 1200lb is awfully light for an 18' CC. Even the classic BW Outrage 18 weighs 1250.<br /><br />You might also be missing on the bottom shape of the boat. I used a bottom factor of 175. (some vee at transom)<br /><br />I came up with 41mph.<br /><br />You haven't mentioned what boat you have or how your engine is rigged and trimmed. Those items can be worth as much as 5-7mph.<br /><br />Good luck. :)
rgg
Let me tell you some past history. Up until spring of last year the engine would over rev 6000 rpm using the 17 in 3 blade alum. prop that came with the boat. I purchased a power tech 19 in ss 4 blade and revs were 5700 and speed was about 44 mph for the first weekend. Came back to my boat a month later and the revs were then 4600 no matter how much weight I put in the boat. I put the 17 in 3 blade back on and revs are 5600 and speed is 37 mph at this point. My boat is a 1994 18.6 ft cc made by OFFSHORE yacht builders. 11 1/2 deg.deadrise modified "V" hull and the engine is a 1992 dt115 Suzuki. I dont know what the engine height is but I can go measure it.
daritzzz
Hello RGG,<br /><br />I own a 17 ft Tullio abbate with a Suzy DT 140(1981) for 5 years now, the big bro of yours I guess(model made untill 1995????).<br />She has never run like she was expected.<br />I only do 5200 rpm's at speed of 45 knots(mph???), optimalised with power trim and power lift.<br />All this with a 13" pitch 19.<br />Boat and engine weight about 1300 lbs( 650kg).<br />I thought all this was caused by bad carb's and timing. but i've cleaned and checked all and find out that there was not the problem.<br />As I start reading here, i've looked into her cylinders and saw that cylinder 3 have been eating water :eek: .All others look a little rusty too, with some scores(I saw on the camera).<br />I've to put a new headgasket to it, so I can inspect them better when the head is off.<br />Maybe you can look also there, and I hope for you not to find the same as me, would be a pity. <br />Did you tried a compression test?<br />Mine was oké 9 to 9,2 bar so on this you can not see if you have a leak gasket. The plug of nr 3 was realy clean, almost like new, what means I've steamed it, caused by the leak gasket.<br />I hope you find the problem a bit faster as me( not five years) :D <br /><br />If you want to read more of mine problem search for "suzuki dt 140 problems"<br /><br />Greetzzz from Belgium<br /><br /> Daritzzz
rgg
Hello Tirett,<br />Yes I did compression test and all cylinders are 125 psi. My big question is - should I tear down this engine to look for some sort of airflow issue<br />maybe reed valves or restricted exhaust flow ? I don't know, I believe I have covered all fuel flow, timing and prop issues. The engine appears to run fine, no misfires, no sneezes, easy starting, good accelerations and idles fine. I have been an Automobile mechanic for 25 years but this is my first boat owned. I am getting all my calculated data from an engineer I work for and it appears logical to me.<br />Thanks<br />Bob
