I?m looking at a new motor for my Pontoon. It would appear that a '99 60HP Bigfoot does plug into my existing harness. It was taken for a test run and all checked out OK. ( and I talked the guy way down in price)
I was told on another thread that my old ?87 115hp I-6 merc had a separate oil mixing unit which was in the boat. That would explain why there was a wire harness coming out of the old motor, and just lying there, where the gas tanks are.
The new(er) motor has the oil tank inside it. So, since the wire harness plugs are the same, I was wondering if anyone knows if the original 1987 115 merc would have also had an oil warning signal in its wire harness?
I did notice that the dash has an oil gauge on it which I though was strange, perhaps that is the oil warning system, and was disabled when the remote oil mixing unit was removed.
I don?t want to buy a manual for this old 115, as it is being scraped ( I will get one for the new motor).
Anyone know the answer, or how I can figure it out. ( IE pins a and B on the wire harness connect to a buzzer in the control box ( or gauge), if it was wired).
Definitely don?t want to run out of oil!
Thanks
Thanks
