Low oil pressure
sebas54
I have a 1987 gm 4.3l merc alpha 1.
What oil pressure is too low to run at 3900 rpms. I have 45psi for the first 15mins. Then it will drop to 30-35psi.
IS this oil pressure to low to run at high rpms?
I changed the sender last year when it was acting this way, then it would stay at 40-45psi. This year it dropping to 30-35psi. I am going to the store to buy a mechanical gauge. What could cause this?
Thanks
sebas54
Re: Low oil pressure
Don't know hours but do know that it was installed 3 years ago from a truck.
30weight oil synthetic
Zackman
Oil viscosity will drop as its temperature rises. As the oil viscosity drops so does the oil pressure. This is one reason for the multi-viscosity oils that have become so popular with today's hotter running engines.
I think most marine engine low oil pressure switches are set for 5-6 psi. The amount of oil pressure is more of a concern to ensure adequate flow and yours sounds pretty good. Go enjoy your boat.​
sebas54
Thank you. I am just always worried while out on the water. I do I have sea tow and haven't had to use for 2 years and I want to keep it that way.
Lupus
Hallo,
If reading the specification for the engine it says (at warm stage) that from 2000 RPMs and up you need 40-60 psi. 30 psi at this high rotation sounds low to me - Not sure it will hurt at all but my engine 5.7GSI reads ard. 45-50 psi at ard. 4000 RPM. Better ask your local dealer if you want to be sure. Happy boating!
