I have a 2000 5.7 EFI Bravo 2 If the low oil temp switch is going will that cause the pressure to run to low at Idle- when I come off higher speed and then down to Idle sometimes the pressure will drop below ten and it never usually drops below 20 also when it drops the alarm goes off-oil pressur at higher speed is fine at 40 psi water temp is good outdrive oils is good. also if this is the case where on the engine do I find the switch? thanks Cool It
