christianL
Thread starter- Joined
- Aug 31, 2009
- 34
When I connect the flushing adapter (rabbit ears) to my 07' Yamaha F225TXR it will run all day long, either in idle or with advanced throttle. But when it is in the water, it will not run at all. The guy at the shop says it's the low pressure fuel pump not working. That's fine, but what is the difference between the motor being in the water versus being hooked up to a water hose?? In other words, what changes in the fuel system when the motor is in the water? This is one of the weirdest things I've seen in a while. Any thoughts, suggestions, or ramblings on the issue? Any help would be great. Thanks!
