Re: Low pressure pump 20psi???
OK.
Im baffled.
Everything lately has been hinting to me it's a timing advance issue. (Mind you I was an ASE Master tech in my youth)
So I pulled the distributor.
It was a replacement from Mallory Marine, as it was less expensive for a distributor with cap rotor wires and coil, than just a cap rotor and wires from Volvo.
Granted the misfire/lack of power was there _before_ I replaced the ignition system. I reinstalled the OEM distributor.
The engine now runs like a raped ape!!
What happened??? The first thing I learned at 15 was how to R&R a distributor.
Im tempted to reinstall the Mallory, to see, maybe a bad wire?? Did I move a wire from the ECU, the ignition module gets its advance from the ECU.
My mechanical instinct tells me to do it, just to see if it happens again. My personal logic says to leave it alone, but if I dont get to the root of this, Ill be on a lake with the problem reoccurring.
Yes, I have a Rinda shunt, yes I used a timing light with advance, so I set it to 8 and timed it to line up with the mark.
Both times timing was dead on.
