Low profile keel roller?
sandiegosteve
I'm looking for a solution for my keel and the front cross member. There isn't much clearance and I've tried to use a standard roller/bracket. The problem is that the even if I drill the holes at the bottom of the cross member and set the roller as low as possible, it will still be too high.
I have a pad there now, but I think it bumps and drags a little to hard. I think a roller would be better and possibly help launching. Ideally I'd like a roller that only sticks up .5"-1" max.
Curious what others have done.
Thanks,
Steve
roscoe
Re: Low profile keel roller?
You don't say what the rest of the trailer is like.
Roller or bunks?
Perhaps you can lower the rearward rollers/bunks a half inch, this will raise the bow slightly.
Or, raise the front bracket on the bunk/rollers.
Or, if it is a bunk trailer, you could replace the bunks with some that are an inch thicker.
sandiegosteve
It is an ezloader bunk trailer.
I like the idea of raising the bunks in the front or adding thickness to the bunks.
ajgraz
I vote for more bunk.
LMK if you need galvanized 3" square U-bolts. I got a bunch leftover from re-bunking my trailer.
smokeonthewater
my vote is leave the pads.... adjust your bunks if you need to is there is too much weight in the pads
sandiegosteve
So here is the solution I came up with. It is working well.
I do plan to raise the bunks 1 notch in the front when I can get time at the ramp on a weekday.
