Thanks Rodbolt for sending me to a real mechanic. I had my 2004 Yamaha 2 stroke 90 HP motor dyno tested like you told me to do and it tested good. The service man at Page's Creek Marine told me that the motor ran perfect but the prop which is an after market ss prop looked to be to big, the blades were wider than a Yamaha prop. He suggested I put a 17 yamaha prop on the motor and it would most likely get the rpm's up to the 5200-5400 range. The after market 17 ss prop I had on it turned up 4200 rpm's. I also tried another after market 15 ss prop and it turned up 4900 rpm's,this was before the dyno testing. I should have the new Yamaha prop on this week so I'll post the results of that performance after the test run.
