low speed sleeve???
dave1
Rebuilding carb. on 1960 40hp johnson. On the low speed needle just behind the packing is a sleeve. The needle threads through this. Well it suppose to be a pressed in fit according to my seloc manual. Mine just felll right out when I took the needle out. Is this sleeve still usable or will the packing nut tighten this up when put together?? Any thoughts
1946Zephyr
Re: low speed sleeve???
The packing should tighten that up just fine, when you reassemble it. I never heard of them being a pressed fit. I've seen them come right out, myself.:cool:
