I'm trying to decide which way to proceed at this point. What I have is a 1973 85hp Johnson which I bought last year. It's on a 20' TC pontoon boat. I'm correcting problems and lack of care by the previous owner(s). I recently installed a new Teleflex tach and it is set to 6P. I have verified my throttle is now opening all the way and my carb linkage goes to the WOT stop when running it. I have the OEM size prop on the engine. My issue is this. While crusing across the lake at WOT I'm taching 2,100 rpm. It doesn't seem to sound like it's at 5,000. Per my OEM service manual I should run at 4,500-5,500 rpm at WOT. Being a noob I'm not sure which way to go now. The motor doesn't seem to be running poorly at wide open. No sputtering, missing, or anything. If the high speed jets plug up will it act like a rev liniter when crusing? Is it possible to be this far off with a prop? Timing issue? Any direction will help, thanks!
