I noticed an oil leak comming from the Alpha 1 lower unit on the starboard side of the outdrive. Its leaking at the seam between the lower and upper units and about 3/4's of the way back towards the transom. I don't think there is a gasket between the 2 units so what could be the cause? Its a slowwww leak but constant and the motor has not been started yet this spring. I don't want to put it in the water until this is fixed..does anyone have any ideas what could be the cause?<br /><br />Thanks,<br />Bob W.
