Lower crank end cap removal
wimico
'85 50hp 4 cyl 2 stroke serial #A131285 needs new lower crank seals. I have the bolts out of the cap but it seems really tight. What can I do to remove the cap without splitting the case? Also would heat help to remove the cap and the exhaust extension plate from the drive shaft housing?
Chris1956
Re: Lower crank end cap removal
Loosen some of the crankcase bolts near the end cap. It should then come off.
The exhaust extension may be held by a bolt. If not, it may just be stuck by the gasket. Usually a soft rap from a wooden, leather or plastic mallet will break it loose. Why do you want to take it off?
wimico
I also have to replace the motot mounts which are giving me a fit to remove. The farther I go into this thing the more problems I find.
