Good Trout To You Sir
Thread starter- Joined
- May 22, 2018
- 85
1st pic shows drive shaft, lower crank shaft seal and lower housing plate of a 1998 4HP.
Goal is to free seized drive shaft using section of pipe, cable clamps, washers to force the driveshaft out/away from the powerhead.
Should I use washers (size, type?) against the lip of this seal component to prevent the outward force of my puller from forcing the crank shaft seal forward as the puller acts upon the drive shaft or is this an unnecessary step?
2nd pic shows carbon buildup near exhaust exit of power head --- if I am successful in freeing the drive shaft, how (and how deep) to go about cleaning this carbon buildup?
Thanks.
Thanks.
