rustybeater
- Joined
- Jun 26, 2011
- 48
OK, I feel like have been on here to much lately but am still having issues with my 1993 Johnson 90hp cross-flow motor. In the first pic you can see that after my rebuild i noticed I was leaking some fuel/oil from the front side of the outboard. At the same time I am also having an issue with the starboard head running about 30 degrees hotter than port. I decided to go ahead and replace the poppet valve and springs and with the bubble back exhaust and with the oil leak i just figure I would go ahead and pull the motor again. Once I pulled the motor you can see that the oil is coming from the lower crankshaft gasket. Now I noticed that there is a little weep hole in this seal. Now my question is: is this normal? should I go ahead and pull it all and replace the seals? Could it be because I have only ran it at idle and have an excess of un-burned fuel or something? thanks for any help.
