Lower end lube-What kind?
lmholmes11
Hello,
Can someone inform me of what kind and weight of gear lube the below motor takes?
It is Model #: E85TLCSA
S/N #: J000195
Evinrude
85 HP
Power tilt and trim
Electric start
20 inch shaft
1980 model.
Thank you!
lmholmes11
Re: Lower end lube-What kind?
Ok thank you. I have also heard of spraying the engine down with WD-40 before the winter, along with all of the rest of the winterizing I plan to do. Does anyone do this to prevent rust, etc?
Bifflefan
As this is a new subject. plz start a new thread.
But just my opinion,, I wouldnt do that. jsut clean it and it will be fine.
ezeke
Many of us use some kind of corrosion preventative on the engines as well as the rest of the motor. I use T-9, WD-40 and Triple Guard Grease depending on the application.
In storage, it's good practice to grease the trim rams and fully withdraw them. It's also good practice to grease the steering cable rams.
Elbo
I use marine lube.Im not sure what the weight is but it will mix with water and still lube if you get a leak.Unless you have three fill screws you need to fill from the bottom screw to force the air out.
