I have a '73 120 hp sterndrive that I just replaced the water pump in the lower end, but when I started it up (while not in gear) the prop is engaged. The engine dies when attempting to put it into drive / reverse. I'm guessing I didn't get the shift shaft in full forward - how do I do that?? Just turning the prop ccw and the shaft cw didn't work for me; the shaft was loose and spinning except when shoved up and into the upper half of the outboard.
What does a shift-shaft wrench do? Can it be imitated by a more common wrench??
I don't wan't to destroy my boat so any help would be great.
Suggestions?? (Thank you!)
