Re: Lower leg removed, cant reinstall properly. 63' 50hp
Victory ! at least partialy. I figured out that I wasnt getting the shifter shaft to fit into the lower units end of the shaft. I got the leg up and can put it into forward and neutral, but I cant get it to go into reverse.
The lower unit's shifter shaft will turn say '340 degrees in either direction, then 20 degrees of neutral. Its pretty confusing, and I think I may only be one degree off. Think if I just move the lobed sproket one position over I might get it working perfectly shifter wise.
I almost cried when I seen the other problem, I have water coming out of the "head". The top (#1) cylinder plug hole pisses water. Not the actual plug hole, but along the edge of the plug hole. I can only pray its possibly only the gasket, but I'm sure its a crack.
It runs fine though, otherwise. I havent had it in water yet, but I got a rain barrell set up under the leg. I let it run for 10 mins and it didnt even sputter once. I put it barley in gear and it was all good.
I dont know if this is normal, but when I first started the motor with the new impeller it pumped out water pretty good, but after around a min of running it reduced to almost less then half of the original amount. I cant see any thermostat mechanism or imagine how it might work.
Thanks again phatmanmike.
I gotta get me a manual. :%
