Lower Pan gasket 2000 50 HP Johnson
Hdog412
Hi everyone,
On my Motor I have water leaking under the motor Cover I am not sure where, but I think that it might be coming from the lower pan Gasket.
When First purchased the boat the Trim and Tilt motor had a leak and the mechanic that fixed it had to used a lot of heat to get the pin out to lift the motor up high enough to replace the seals in the Trim and Tilt Motor. I am thinking maybe that caused some damaged to the gasket. Any ideas on how to change/repair it. Or any other thoughts on where that water might be coming from? It is the only thing I can think of, aside from that the motor runs great, but I am noticing some rust forming on the outside of the lower spark plug.
Thanks
Regards
Harry
oldcatamount
Re: Lower Pan gasket 2000 50 HP Johnson
To change that gasket, you will need to take the power head out. Not as bad of a job as it may sound. The seals that really count here are the ones where the driveshaft enters the crankcase. Those are very important.
