lower seals help needed
tekk220
I removed my lower unit and replaced the impeller. now I am attempting to replace the prop seals since I have oil leaking and I am stuck. do I need to remove that carrier that holds the seal to replace? the seals have a metal case so I cant just pry it out. any help is appreciated. thank you
Texasmark
You can leave the LU intact. Just remove the prop and thrust washer on the prop shaft and get to it. Drill a hole in the metal and take a pick, like a SSdental pick, stick it in the hole, or holes if you choose, and pry the outer seal out. Then you can grasp the metal of the inner seal and pull it out. Note they are back to back when reinstalling....one keeps oil IN and the other keeps water OUT. Manual lists Red locktite coating when reinstalling...auto parts stores carry it.
tekk220
thanks so much. you gave me the motivation to give it another go 62406878648__68B40FCA-D84B-4AF1-BEFE-420A5C5149F1.JPG
Texasmark
The screw is a great idea too. Glad you were successful.
"You gave me the motivation to give it another go." I find that my motivation is challenges that I have accepted and overcome over my life. Like seeking an answer to something: If you don't ask the question, how can you expect an answer....if you don't try something how can you expect to succeed?
