After hooking up my my shift interrupt switch and trying it out last week--it works! I found out while shifting into reverse from neutral it would stall, so today I adjusted the lower shift cable (it wasn't at exactly 6") so I adjusted it to 6" then turned the barrel 4 turns (per the manual). going into forward no problem, but when going into reverse it would take about 1/4 throttle or more before it would kick into gear. so I readjusted, and it seems much better now, but when the engines off, and in neutral I can free spin the prop in either direction,(yes I know I should be able to spin the prop) I hear a clicking sound -is that okay?
And yes I wanted to try to adjust the cable to see if that corrects the problem before I replace the lower cable.
I'll know for sure tomorrow when I take it out on the water!
