rickasbury
Thread starter- Joined
- Jul 13, 2011
- 878
so, end of a long saga )( and learning curves!) getting my motor back in (350 MPI in a 270 Rinker), out drive back on, up and running everything go good BUT- so back track a bit, had a leak and thought it was bellows so re did that along with gimbal on lower shift cable...still had a leak so pulled the motor and rebuilt the transom assembly with new gasket, all new parts and pieces and getting it finally back together.
So, fired it up- I don't recall that the lower unit was turning but more concerned I was pumping water through......then, figured I better put it in gear and see if it goes into gear smoothly forward and reverse looking to see if it does and it did....but I did not notice both in forward and reversed, the outdrive still spun in the same direction and when I put it back into neutral, is still kept moving....I have been looking all over for the shift adjustment and there seems to be varying opinions how to do it, what is yours? Would you think I have an issue with the engagement of the the cable and the outdrive? I'd sure hate to think I'd have to pull that back off at this point....
