lower shift cable tube replacement
ohio river rat in KY
can you just get the outer cable i guess just the cable tube with the threaded end that goes into the gear box? my inter cable is good it has pulled out of the threaded part, after just changeing the bellow:facepalm:and put all back together..knew it went back to easy. if so what would be the part # thanks
Pete104
Re: lower shift cable tube replacement
No clue as to what your driving. I don't get what part got messed up on you!
1983 alpha 1 the lower shift cable tube (sheath) my core wire is good, the sheath came out of the brass that threads in to the gear box, i know you can get the core cable but what about just the sheath part?
achris
More fish than mountain goat
No, the lower shift cable comes as a kit and none of the parts are sold separately.
Chris.......
NHGuy
They don't cost much, and that's what you need so that's what you have to get. Sorry.
Pete104
Hope he knows what went wrong!
yea had to change out the bellow and doing a full restore and its been pulled and tugged on here and there and its been there sence 1983. good thing it done it now i guess and dont have to worrie about it now
The shift cable is from '83?
yea according to the P.O. the only thing had been done was newer bellows, look like in 1985,prop which was eat up first time out with him,and new floor,which mint a peice of plywood over old, and that was all ever done to this boat. dont think he was lieing cause been replacing just about every thing should have me a new boat b-4 long:), the hard way:facepalm:
