Lower Shift Shaft Seal question
ljs22
I am getting ready to replace the lower shift shaft seal on a pre-alpha 140 drive. I think I remember reading somewhere that you don't want to actually remove the shift shaft as the dog at the bottom can get out of alignment and you then have to take the entire lower unit apart. Is this true? Is it better to loosen the bushing and slide it up and not move the shaft? Is that possible? The manual is very vague on that point and instructs you to remove the shaft with no warnings of the ramifications of doing so. Can someone please clarify that? Thanks.
Don S
Re: Lower Shift Shaft Seal question
You don't have to remove the shaft if you don't want to, just slide the bushing up while holding the shaft down.
ljs22
Just for verification what would happen if the shift shaft was removed? Would I be in a world of pain?
Don S
Probably nothing if the drive was sitting straight up and down.
