1987 175 mercury
Thread starter- Joined
- Dec 30, 2011
- 17
I have a 18.5 1987 stratos vt rocket with the factory 175 that came on it.thru some tlc it runs great.set up with a 4 blade prop.I am know addressing another issue that i bought it with.The skeg had been broken off at the ramp by the previous owner.He had a skeg cover on it and that was fine until the time came to fix it.Now is that time.I have water pump issues.The boat always wanted to idle hot,as soon as i jumped on plane it would cool.I live in south florida and run shallow and get on plane shallow.My initial thoughts were to have the lower unit taken apart,weld on a new skeg,re-seal and put lower unit back together,making repairs on the water pump issues all at the same time.Since the tunnel hull of the boat is probably going to give me the ability to raise the engine to a higher mounting and i need shallow water capabilities are there other options that would allow me to gain those needs on similiar expenses that repairing my existing would be.Possibly fixing my hot idle issues and allowing me to have additional water pick up when running the engine high.Any ideas on a different lower unit or avenues to gain more knowledge on these issues would be appreciated.Also info on setting up my engine height with this hull.THANKS!
