davidkockler
- Joined
- May 31, 2005
- 20
I read a post here that said if the drain plug has no undercut at the end of the threads, you should use a single-use nylon washer. Can you use a rubber washer? The rubber washer should seal well even when reused. It is a tad thicker than the nylon washer, but not enough to be a problem. <br /><br />Anyone know why nylon washers are used on some drain plugs?
