Lower Unit Fitment
Andre'
Hello,
I am trying to fit a Johnson 1996 130 HP gearcase to a Johnson 1990 115 HP. I understand the 96 has a two piece drive shaft and the 90 had a one piece. I do not have the gearcase off of the 90 model to compare. Can anyone tell me if they will interchange, or what I can do to make the 96 model work?
Thanks for any advise!!!!
boobie
Re: Lower Unit Fitment
The 130 had a V-6 style gear case and may have a different gear ratio.
Andre'
boobie,
Thanks for the reply. I could live with a different ratio, but do you think the driveshaft lengths and splines would be similar to allow it to bolt up as is?
There were some changes made in length of splines / depth of splines in crankshaft.----Tried to fit a gearcase one time and the starter would not crank properly when bolts were tightened.---Loosened the bolts and it cranked OK.-----Get all the facts / measurements to compare before handing over the coin.----Shift rod is likely different too.
