Lower unit gear oil had light green streaks--aeration or water?
jacko137
1977 MCM 120 with 1 drive.
I was winterizing last night and when I went to drain my outdrive I noticed it was light green at first--looked like foam--before returning to primarily green/blue (I use Mercruiser synthetic). Occassionally it would streak with the light green as it continued to drain.
Am I dealing with a water leak or is this common for lube that has been run on maybe 30 hours? BTW--no major chunks of metal anywhere to be found.
Haut Medoc
Re: Lower unit gear oil had light green streaks--aeration or water?
Hard to say with out seeing it, but it does sound like it.....
The best way to find out if you have a problem would be to pressure test it......;)
Ayuh,... Sure sounds that way,...
Merc. gear oil doesn't aerate,+ if it did, it'll settle out in less than a day...
Probably a hour or 2 maybe...
crazy charlie
I have had the same for years when i use Lubrimatic green.On my alphas and on my Evinrude.Charlie
