I have a 1984 Johnson 25 HP that I recently blew the lower unit. About a month ago I redid the waterpump and corresponding seals. When the lower unit was off I could turn the driveshaft and it would make no noise. This is my reason why I believe the noise I have now should not be present.
I bought a 1984 Johnson lower unit today to replace mine. This lower unit makes a noise when you turn the driveshaft that sounds like something is grinding. I took it apart and the gears looked like new and nothing looked out of place. When reassembled and re-oiled the noise is still present. I do not want to put on motor and run and have this lower unit fail if this noise is bad.
Both units were off motor when above symptoms occur. Old lower unit did not make any noise so that is why this lower unit concerns me. Any suggestions to try?
Thanks!
Thanks!
