Moody Blue
Thread starter- Joined
- May 24, 2004
- 3,136
In the process of putting back together a lower unit for a 1971 Merc 800. The disassembly thread is here
http://forums.iboats.com/showthread.php?t=401704
In summary, I'm replacing a driveshaft and using the existing bearing carrier, pinion, fwd and reverse gears in the same housing. Only other thing new is the tapered upper driveshaft bearing and race.
When checking the pinion/fwd gear engagement depth, I discovered something the just doesn't look right. The pinion gear appears to be not nearly deep enough to fully engage the fwd gear properly. The manual says to remove shim material from under the bearing race (tapered upper bearing), BUT it looks like I need to lower the pinion gear 1/8", not just a few thou.
As a comparison, I checked the "old" lower unit that was causing me troubles. The pinion depth appears to be about the same, 1/8" too shallow.
I've attached two photos showing the pinion position relative to the fwd gear in both lower units (one I'm putting together and one that was damaged).
From what I've seen, I would say the lower unit castings are wrong, as far fetched as that may seem. How can the engagement be out by so much?
Any insight is much appreciated as I hope to get this thing finished up this weekend.
