Lower unit interchange
preacha
Hello everyone. this is for a friend of mine. He has a 1984 150 Black Max and needs a lower unit. What will interchange on this model? thanks Lee
j_martin
Re: Lower unit interchange
Almost anything (right driveshaft length of course) from a 2.0, 2.4, or 2.5 L V6 engine. Everything from a 4 inch 1.78:1 LU off an XR4, to 4.5 inch 1.87:1 standard LU. Most of the sporty stuff will bolt right on.
Earlier ones had a spring load preload pin on the end of the driveshaft. Later ones without the pin are better. My mechanic has had pretty good luck with the aftermarket LUs available.
hope it helps
John
Faztbullet
A correct unit will be a 2:1 ratio but you can use a 1:87 but may have to do some propping changes.....
