geekomatic
Thread starter- Joined
- Feb 12, 2005
- 136
Been awhile since I posted due to my workload.I've been making the big bucks for the Man, but none for me.<br />At any rate:This concerns my little 58 Fast Twin 18.<br />A few months ago I took apart my lower unit and discovered that the bearing retainer pin on my forward gear had been pushed down into the bearing housing. Bearing housing So I searched for five freaking weeks and finally found that little pin for a whopping $1.79.I bought three for good measure.I managed to drill out the old one and get the new one in place. new pin.Now, first of all-I know the new pin looks a little loosey-goosey sitting in it's new hole.That's OK.I'm not finished.I plan to shore up the pin and get it nice and tight with a little JB Weld or solder of whatever.Here's my issue. The new pin-hole and the new pin are dead-on-the money in the correct place.I verified this by placing the gear assembly into the housing after a temporary install with the pin.The thing fits like a glove. Gear in housing The holes all line up with the pins,etc.<br />The thing will not turn for squat once it's installed.I cannot turn it by hand using the drive shaft rod or the prop shaft.Everything is lined up fine and all of the gears are in great condition, as you can see in the photos.I can put the clutch dog in either neutral,forward,or reverse, and the gear assembly will not move by hand.It's almost as if that forward gear housing pin does not belong there. If I take that pin out and re-seat the gear assembly,It spins by hand normally with no resistence.Am I missing something? I'm not going to re-assemble this thing until I know it's OK.This is the only thing that is keeping me from cranking the motor at this point.Do I need to go searching for a new lower unit?
