therigwelder
- Joined
- Apr 11, 2009
- 29
ok my lower unit will not go back in place, ive used every idea that you all have been giving me,ive got the motor in reverse,i am rotating the driveshaft from the prop to line the splines,the gear selector rod is started in its hole.I am 3/4" away from LU closing up.could the water pump seal located on the copper tube not be lining up with the pump housing bore? i have been f###ing around with this for 2 days.it came apart so easy that i cant understand why its KMA
1974 mercury 850
