WrenchHead
Thread starter- Joined
- Feb 15, 2009
- 120
I'm running a 2004 Merc 60 hp 4-stroke EFI and recently I replaced the two seals for the prop shaft and also replaced the O ring separating the lube oil sump from the exhaust chamber. I used compressed air at 10# in the lube oil sump and sprayed soapy water on the O ring and the seals to check for leaks. The air pressure held at 10# and I didn't see any soapy bubbles. So I vented the compressed air, filled the lower unit with lube oil, and left the prop off so I could check for an oil leak from the O ring into the exhaust cavity. After three days I see oil began to puddle in the exhaust cavity. How can the unit pass the compressed air test but then have lube oil seep past the O ring into the exhaust cavity?
