chris in houston
- Joined
- Jan 19, 2010
- 23
Recently replaced impeller and gaskets on pump. The housing and bottom plate looked fine and smooth.
When on muffs, water spurts/dribbles out of the interface between the top of the lower unit and the rest of the engine. This happens before I start the engine, and leaks in proportion to the garden hose pressure on the muffs. Keeps leaking after starting engine. Might have done this before I replaced the impeller, but I never looked.
Seems the entire cavity that the water pump sits in must be filling with water from muffs for this to be happening. Is that cavity supposed to remain dry?Is that a problem? If so, what needs fixed?
PS: I did not apply any sealant to the top of the LU before rebolting to engine. Should I? I doubt this is the problem, but just thought I'd ask. Without it, seems that same cavity would eventually fill up with lake water from inward leakage.
Thanks in advance for your help!
