I am not sure if I should start a new thread?
Current issue/problem:
Everything was going fine until I struggled with the shift shaft alignment.
After several tries making sure the upper and lower shaft were connecting, I
kept having problems testing the gear shift. It won't come out of forward?
I noticed that when the lower unit was off that the shaft will rotate left/right.
Before attempting again, is there a way to make sure the shaft is in the right gear position? ie. should I rotate the shaft all the way counterclockwise or clockwise?
Thanks for helping.
Thanks for helping.
