Re: lower unit mounting bolt stuck and stripped, help!!
i have second guessed myself on this, but i removed the bolt where the shift rod connects, i removed the trim fin and the bolt underneath it, and i removed the bolt directly in front of the trim fin. i have been following the service manual precisely, and i have retraced my steps just to make sure. If there were several bolts left, I wouldn't be able to twist the lower unit so much. it will twist back and forth by almost half an inch, but i cannot even fit a hair in between the lower unit and upper unit in the area of the seized bolt. it is stuck and stuck good. i have heated the thing up so many times that i can't imagine the heat doing anymore good. i probably put the torch on it 10 - 12 times today. i have pulled and wiggled the engine so much that the entire boat wiggles, in fact i have put so much weight on the lower unit when trying to break it free that the front of the trailer would leave the ground. it is absolutely ridiculous how seized this bolt is. if i didn't know any better, i would swear the bolt was welded in place.
