Lower unit not square after ram replacement
tomjode
Hello,<br /><br />I have a 1986 Celebrity 190 bowrider with an Alpha 1.<br /><br />I removed both tilt/trim cylinders. The lower unit was supported with a rope during the procedure. <br /><br />I reinstalled the aft(closest to hull)cylinders first with no problem. Then when I went to install the forward portion of the cylinders I noticed that the port side cylinder appeared crooked and the shaft that runs through both cylinders would not make it through. After working the cylinder in/out I was able to get the shaft in and the bolts on without any binding. <br /><br />When I had the nuts snugged in I notice that the lower unit has a slight lean to port. To clarify, if I draw a line down the center of the gimbal housing and lower unit, the lower unit appears to be cocked very slightly left of center. <br /> <br />I have not tightened the bolts all the way to the washers yet because I am concerned that somehow I have screwed something up!<br /><br />The shafts do not feel like they are binding.<br />Also they slid right through both cylinders nicely.<br /><br />Am I seeing things?<br /><br />Will the unit square up when I finish tightening the nuts?<br /><br />Any help or thoughts on this would be very much appreciated.<br /><br />Thank you<br />Tom
north40
Re: Lower unit not square after ram replacement
Tom,<br /> If you post this in the Mercruiser repairs forum, someone will be along to help you. Good luck,<br />Bob
tomjode
Thank you north40. I have moved this to the correct forum. Maybe it is my eyesight!! <br /><br />Take Care<br />Tom
