Lower unit oil leak through weep hole after impeller replacement
runninfarmer
Hi All,
I recently replaced the water pump on my Alpha one, Gen 2 drive (2002 year). I also replaced the quad ring seal. After I got the lower unit back together, I went to refill the lower unit and it started puking out of the weep hole. After I dropped the lower unit again, I noticed the quad ring looked fine and was still in the recessed hole. Did I do something incorrectly? Is it possible for it to get dislodged, and then "relodged" upon inspection? I order a new seal just to be safe, but it was a Quicksilver seal. Anyone ever experience this?
Might be other than the quad ring hole.
Is shift shaft seal good, pump housing leaking?
Scott06
Hi All,
what did the driveshaft seal under the water pump look like? the seal carrier (yellow plastic) can deform especially if they run hot or was run dry.
Given the age might be worth pressure testing while you have it apart
runninfarmer
tried it again, this time with aviation gasket sealer on the quad ring. Happened again. One thing to note, I still had the reservoir cap on, but vent hole plug was out to vent. Does it matter if that cap was on though it was venting? I noticed after dropping again the shift seal was dry but the water pump housing was wet with oil all to the splines. Here’s a pic:
SO your saying the splines are wet with lube at top of shaft, down to on top the pump housing?
runninfarmer
Splines are dry, but shaft was wet to about right at base of splines and on top of pump housing all wet with oil.
Also from what I can tell, it was dry around the quad ring, so I think that seal was working correctly.
Bt Doctur
remove the keyway and base plate and pressure test the lower again
crazy charlie
Hi All,
Quad O ring should be glued into place after carefully thoroughly cleaning where it is seated.This however does not sound like your issue however doing this procedure correctly will remove any doubt re; leaking from this area. In your case my guess is drive shaft seal in the upper.Charlie
Scott06
Would guess its either the seal below the water pump or the driveshaft seal in upper based on leaking down the shaft below the splines. Although not sure how it would end up inside the pump unless it was the yellow carrier seal. really need to pressure test. Can do the whole drive together, can do the lower alone by plugging the oil passage (clamp metal over it) to do the upper alone you need a spare drive shaft
runninfarmer
Well I think I discovered my issue. I found an additional seal on the drive shaft below the carrier seal. I’m assuming that’s not correct? This would have prevented the carrier seal from going all the way down?
Scott06
Yes that should not be there onky the seal in the yellow carrier someone must have changed the carrier and not seen this seal below it
runninfarmer
Well, I was in denial, but turned out it was the upper drive seal and it looks like there was a seal out of place. Looks chewed up.
runninfarmer
I bought kit 26-88397A1. It comes with one double lip seal. Is that all I need? I saw there’s also a larger diameter seal, but I don’t see one in my gear case. This kit comes with a large one, but I don’t know where it goes?
Scott06
Larger diamter is for the input yoke shaft seal. you will have to remove that to remove the vertical gear to get at this seal
runninfarmer
Do you think I should put the oil seal in place with gasket sealer or oiled sides? The manual states to lightly oil the bore.
runninfarmer
I went ahead and coated the outside surface of the seal with sealer. Seems to be working well, as i didn't get any oil pouring out the weep hole!
Funny enough when I pulled the drive, I found two plates at the bottom of the exhaust hole of the bell housing. I believe they're remnants of the Y-pipe shutters? Might explain why I've been running a little on the hot side (separate issue I've been fixing).
Scott06
Would think the hot running is what lead to the shutters falling off, usually when water flow is impeded everything on the exhaust cooks off
