CaneCutter79
Thread starter- Joined
- May 24, 2009
- 454
A) What color should lower unit oil be? Just drained mine and it was black as coal (green tint if rubbed to thin layer) and very thick consistency.
B). What oil type do I use to refill
C) I supposed to pump the oil in from the lower plug hole until the lube comes out of the top hole.
D) What pump do I use? And where can I get one to refill? I'm hoping local.
I'm pulling my carrier bearing assembly (almost done) and I will be replacing the seals only.
No.......there was no sign of water in the oil. No milky color at all. Just black, thick. I suspected it may be old and needed replacement.
Thanks to all who answer questions as iboats! The info is gold and very helpful!!
