Lower unit oil screws stuck
zach103
Thats pretty much the deal.. Both the top and bottom srcrews for the lower unit oil are stuck .. what can i do to move them
junior1113
Re: Lower unit oil screws stuck
do you have one of those huge flathead screw drivers or i would try that or an impact driver with a large flathead attachment before trying to appempt to tap them out
boat1010
I second both of the ideas. Flathead screwdriver with lots of pressure toward the screw. And the impact driver works very well also. Good luck..
zach103
i tried the regular big flathead screwdriver thats how i usually get them out.. .. my boss has the impact one.. ill borrow it tomor .. he said i could try heating them up.. but i wanted o ask you guys about that first..
tx1961whaler
Nah, don't heat it up. There is a nylon gasket or rubber o-ring under there. Makes for a big mess. Impact driver is the best bet.
wbeaton
Impact driver with the proper size screwhead. Don't heat it. There's oil in there.
F_R
What everybody says. Use a hand-impact screwdriver. They aren't stuck, just tight. They are supposed to be tight. The threads are bathed in oil so they are not corroded in place....or if they are, it is full of water and you have a lot more problems than just getting the screws out.
mars bar
The good ole 4 way tire wrench usually has a nice big flat head driver on one end providing plenty of torque.
zach103
a buddy of ours fixed something in the lower unit last summer so i know if there was water he would have told us.. . ill try and get the impact tomorrow
Fl_Richard
I've successfully used a less than proper size screwdriver angled in the threads and a hammer and drove the screw in the proper direction. It does mess up the threads a bit but if your careful it will help.
Good luck! Dont forget to replace the nylon washers. They are a one time use item.
Mark_VTfisherman
And you don't have to beat the thing like a fence post either- it will come out.
Something you might want to try first is this: I have a very large Klein screwdriver that I re-ground the end on. The end is nearly as wide as the plug slot. I made it hollow-ground like a gunsmith's screw driver- the parallel sides don't tend to cam out like tapered sides do. I was careful to not heat it; took my time and cooled in water before it even showed any signs of getting hot. That keeps the temper.
The nice thing about the Klein is that it has a hex-shaped section near the handle that you can put a box end wrench on. That screwdriver has saved me on so many things, but worked perfectly for my old Johnson lower unit screws. That method or the impact driver will work. Don't beat on the plug unless it is a last resort and you already have replacement parts.
