tom hovanec
Thread starter- Joined
- Jan 14, 2024
- 2
lowered out drive and lower unit oil poured out of water intake ports . it has a reserve bottle and drains down when sitting over time.
Most likely the vertical driveshaft seal below the water pump. not sure which drive you are working on or what age. You can pressure test the drive to see where it is leaking .lowered out drive and lower unit oil poured out of water intake ports . it has a reserve bottle and drains down when sitting over time.
Assuming it is an alpha gen 2 Check the top of the seal carrier #19 they can get deformed from heat over timethanks, that shaft seal is my go to repair,and a new impeller. all original internal parts from 2007.
