lower unit oil vs. gear oil
Status
Not open for further replies.
zzimmer3
I've done a search without success, searching for the difference between regular gear oil and lower unit oil. is there something in the oil since its used underwater?
just to make a point, I just spent $900 getting the lower unit rebuilt-so i'm not taking any shortcuts, I've just wandered for awhile.
thank you in advance for the input.
matt167
Re: lower unit oil vs. gear oil
It's all spec GL-5 unless you’ve got an old electric shifting OMC. I think it's marketing but I still grab OEM quicksilver gear lube just because
Bt Doctur
Shame, if it is a Merc ,you could have had a new lower for $600.00 and with a 3 year gaurantee
seahorse5
Here is a picture of various lower unit oils and how they hold water after 24 hours. This is from a Bass and Walleye magazine article a few years ago that tested all the common oils.
82rude
according to one of my older manuals do not use auto-type gear-oil as it doesn't have anti foaming or anti- expansion qualitys to it which is necessary in a marine lower unit.
TD_Maker
Just do yourself a favor and buy the best MARINE GEAR OIL GL-5 rated you can afford. Stay away from automotive gear oil, because it will foam up like crazy inside of a gear box.
seahorse5
Be careful of GL-5 lubes as many are not recommended for older gearcases or car manual transmissions as the additives will affect brass and bronze bushings and other parts.
That is one reason why Yamaha does not want their V8 & SHO Heavy Duty gear oil used in older engines.
JimS123
So just use the manufacturer's OEM marine lower unit oil. That's not a shortcut and you won't have to think about it later. Maybe it might cost $5 more than some generic oil, so what's the problem?
mrmamiller
Click image for larger version. Name: Gear Oil mixed with water.jpg Views: 21 Size: 62.6 KB ID: 212202
So, is it better to have the oil and water separate or to have the water held in suspension with the oil? I guess if you want to pull the plug and drain off water, separation would be better. If not pulling the plug, I'm guessing water in suspension is better...I really don't know. Experts?
zzimmer3
thank you all for the input, like I said , I was curious as to what made it different. thank you all.
seahorse5
Water kept is suspension in the oil prevents corrosion on the gears and bearings, plus still has lubricating properties. If left in over the winter, the separated water freezes and damages the gearcase.
MakoNY
Based on that picture, the Evinrude oils seem to hold it in suspension better.
seahorse5
That is the Evinrude E-TEC oils that are designed for 3 years or 300 hours of normal use. That XR has been discontinued and the HPF-Pro is now recommended for all mechanical shift gearcases.
fishcrazy50
Resurrecting an old post. My 96 Yamaha 225 2-stroke's only requirement is Hypoid 90w as specified in the owners manual. It now wears and SEI lower unit has it was a reverse rotation, not standard. In contacting SEI they said to stick with GL-4 as GL-5 does not have the additives to protect the bronze bushing. Any 80 or 90w GL-4 will suffice. In looking at a pic you can see the automotive hypoid 90 performed as well as the premium Mercury/Quicksilver product.
GA_Boater
No, ya don't.
Closed
Status
