Lower unit oil
bones774
I was just at one of the big box stores and they wanted 10 bucks a quart for Quicksilver High performance gear lube. Sounds a bit expensive, is that about right? is there a non high performance? any other substitutes available?
Thanks
IES99
Re: Lower unit oil
I've been using the Pennzoil product.
havasuboatman
Ensign
Re: Lower unit oil
Quicksilver is the bargin brand. If you buy the Mercruiser brand it's $15-$18 a quart.
$10 is about right. If yours is a Merc drive, use the hp gear lube. It's good stuff and holds up well to minor water contamination. Automotive lubes loose their lubricating properties if water gets in them.
$30 a year is worth the insurance, trust me.
bones774
Re: Lower unit oil
I have a merc alpha 1. I did see that the quicksilver has emulsifying agents in it.
I guess I'll have to go back and pick it up.
Thanks
180shabah
Re: Lower unit oil
Which generation I or II?
genIs can use the "cheaper" premium oil or equivilant
genII need HP only
bomar76
Re: Lower unit oil
One is not enough to fill an empty drive.
Buy two.
bones774
Re: Lower unit oil
I believe I have a Gen 1. My trim cylinders go to the farther edge of the body, is that correct? ser# OC363861
bones774
Re: Lower unit oil
genII need HP only
Just for my info what is the cheaper "equivalent"
Thanks
bigskiohio
Re: Lower unit oil
spend the 30.00 and buy the merc + my mech swears by it.
liquidlew
Re: Lower unit oil
I get mine at Walmart for $9 a qt., at least that was the price when I got it last year. You gotta buy 2 qts. I just filled my Gen 1 and it takes aprox. 1-1/4 quarts. The tricky part is unscrewing the hand pump and getting the plug back in without losing half of what you put in so you gotta be quick!
HT32BSX115
Re: Lower unit oil
$9 or $10 per quart is a bargain!
You only change it once every 1 or 2 years!!!
If you're worried about saving a few bucks a year, how do you buy gas?
bones774
Re: Lower unit oil
Wasn't worried about the total cost, just if the price per quart was reasonable.
Believe me I also own a Harley, so it's "H"undred "D"ollars and "Break Out Another Thousand" as my motto's.
I wonder if airplane owners have their own motto??
bomar76
Re: Lower unit oil
Yeah...
pull the stick back and the little houses get smaller
push the stick forward and the little houses get bigger
It's taped to the instrument panel of every plane.
bomar76
Re: Lower unit oil
Feel free to go ahead and put it up whenever you see it missing.
