zippy83
Thread starter- Joined
- Jan 1, 2013
- 499
Re: Lower Unit Oil
That is one mistake I have done before I started to drain the old fluid and that is I did it while the LU was cold. I did notice that the drain plug is not magnetized though. I will go to my local Mercury dealer to see if they can get me a new one. I guess I could run it a few times if the weather gets better soon, and then replace the oil again alonf with the new drain plug.
The proper way to change gear oil is when the LU is still warm. The oil flows a lot easier minimizing retained fluid the particles are still suspended in the fluid instead of falling out of suspension and collecting in recesses and such that don't drain when the fluids are cold. Make sure you have a magnetic drain plug as well.
If the inside of your LU is that dirty, fill it up and run it for a couple of days before changing it again. Once clean it will stay that way unless you have mechanical tolerance issues or the fluid is contaminated. I change my LU oil every October. Most years there is still a tinge of green left in the oil even after 200-250 hours of use
