Hi all.I have an 88 merc classic 50 that has water in the Lu oil ( AKA biscuit gravy). I have ran a pressure test on it.It started leaking around the gear shift shaft at 7 psi but would hold 5 psi overnight. i can put LU in FWD and hold prop shaft and as the drive shaft is turned the pressure would drop from15 psi down to about 8 psi I definetly have water in the oil per the spatter test and have a lower unit seal kit on order. Would these pressure readings be typical.I haven't had this motor on the water yet so the water showed up on muffs after only about 10 minutes running time.Thanks in advance
